Juddla
Aug 19, 2019Explorer
Bikeboy57 wrote:
Ok your testing somewhat eliminates the loose wire/bad splice. You said no problems when hooked to shore. So let's test the gennie without the ATS in place . Wire the gen leads to the input leads going into the coach. What happens?
So remove shore from ATS and replace with gen leads?. OR
Disconnect load lines to coach at Switch and hook gen leads direct to them?
38,773 PostsLatest Activity: Apr 22, 2026
