lfrese wrote:
Do I need to run the gas out of the generator too?
Do I need to put water back in grey tank with chems?
Should I put anything in the fresh water tank?
IF you really will be using it every weekend......then you NEED to do pretty much NOTHING.
If the gen is used some each weekend, it will be fine.
If the black and grey tanks were flushed out a bit after emptying, all they really need is a gallon or two of water. No chemicals needed until there is waste in there.....and no extra chemicals are needed in the grey tank EVER (well except maybe cleaning before winter storage).
The fresh water tank should have: Fresh water left in it, if your water source is good.
Be sure to turn the battery switch to OFF unless you can connect an automatic charger while not in use.
