haste maker wrote:
is there a way of protecting the water lines for a short period of time?
IF your description of the conditions is accurate...then yes.
I live in north central Florida where it works pretty much as you describe and I never "winterize" anything. I suspect that pretty much nobody does.
Make sure that the pump is OFF and open all of the faucets that you can. That's it.
Pipes break (usually) because of pressure built up by the "freeze plug" growing toward a closed valve. If the pressure can't build up, there should not be a problem even if a little ice forms in a line.
It takes more than a few hours of barely freezing temps for things in the RV to actually get that cold.
If it will make you feel any better, ask an RV dealer or three in your area.
