Buster85's avatar
Buster85
shower stall crack
Hi, the shower stall in my 2014 Fleetwood storm 32v has developed a crack and consequently leaks. The insert is made by Duo-Form Plastics. I contacted them and they said it would have to be replaced. Can anyone recommend a repair that can be made, such as a silicone caulk or waterproof adhesive that might work as a stopgap ?? Thanks!
  • An automotive body shop may be able to assist you. This shower stall, I believe is like an epoxy resin/ fiberglass reinforced type of product. We had a sink in our Old Jayco Grayhawk, made by the same firm that had a hairline crack in it and an auto repair guy fixed it for us and matched the color pretty good!
  • is this not under warranty ? You might try etenbond.but with continued use the crack will just get worse.if like mine coachman, there is very little support under floor.
