DraginRat
Dec 01, 2014Explorer
Fred;
If there is a compartment under where the slide rails are, look inside the compartment above the door. There should be a small cover box. Remove the cover, and you should see a roller with a couple bolts that adjust the height of the roller. That may be the way to adjust your slide. Hope this helps.
Ken Gasbarri
Ken Gasbarri
