dougrainer wrote:
The ONLY correct repair is to replace the complete slide gasket. The new gasket comes with the metal clip installed. They do not sell the metal zipper clip by itself. NOTHING will adhere the existing gasket to the gasket frame edges. Only the metal clips will hold it in place. Doug
I had the same problem on one of my slides and did indeed replace all 3 of my slide seals.
My slide toppers needed replacing as well so I did them at the same time, as the toppers are in the way of putting the seal in place across the top. Not a fun job, but glad to have it done.
