SyJen wrote:
tk, did you replace the seals yourself or have it done? Do you know the method and material that was used?
I did it myself. I mainly just used my fingers to seat the new seals, but on a couple of sides there was not enough room for the seal AND my fingers so I used tools there to press the seal into place. Sorry, I don't remember exactly what I used - a wood chisel, maybe.
I just started at the bottom of one side of the slide and worked my way around. To better conform in the corners, Monaco had cut the blade, overlapped the edges and glued them together. I used Super Glue Gel for that. To make sure I got the right thing, I ordered directly from Monaco, but the part for mine was
ED50470 - Deal, Double Bulb w/2" Blade. Your rig may take something different.
