BigDaddy1951's avatar
BigDaddy1951
Slide Out Sync
I have a 2007 Winnie Voyage 35L. The front slide is out of sync. It is a Kwikee and has two motors that go through the frame. I found the front direct drive motor. I believe I need to disconnect the motor from the rodthat moves the slide. Removed pin but could not move the rod in or out to disconnect gears. Any ideas? Didn't want to use brute force, yet!
