10forty2
Jun 09, 2015Explorer
Slide Problem
Probably not a HUGE issue, but I don't want it to develop a leak....
I noticed the other day when rolling the slide in to get rainwater off the topper that the slide when fully retracted didn't quite go all the way in on the front lower corner....only noticeable from the outside and only slightly not against the side of the coach. I pushed on that corner slightly and it goes in for the seal to contact the side of the coach, but comes right back out again when I release pressure. I noticed today, when extending the slide, the same corner seems to go all the way out and when I release the button it rocks back in slightly. I tried retracting it again and it does the same thing...it comes all the way in and then when I release the button it rocks back out slightly on that corner.
The slide extends and retracts equally on both sides and feels stable when fully out or in. I am very OCD about keeping the rails and gears lubed with dry lube, and have not noticed it not sealing completely before.
Any ideas of where to start looking for problems?
