gkitchens
Jul 29, 2013Explorer
Teddy. You suggested spraying a dry lubricant under the sofa when it is out. When you look under the sofa, will you see the humps where the slide needs to get over to lay flat? Did you have trouble with your slide out and tried spraying the dry lubricant and it corrected the problem? Thanks
38,705 PostsLatest Activity: Jan 22, 2025
