TempatureContro
Dec 15, 2013Explorer
Could also be the control board for all slides. I found mine above the batteries after 1st one slide and then another quit. My board was for all 4 slides and I found it on e bay for $99.00. You can test your Power gear slide out motor easily with some wires run direct from 12v. battery. And yes, you should be able to crank your slide in or out with a 3/4 socket and rachet using the fitting at the back side of the motor,IF your shear pins are intact.
38,783 PostsLatest Activity: Sep 10, 2026
