chucl66's avatar
chucl66
slide won't work, Damon, Intruder, 2000 FIXED!!
My living room slide, electric, will not go out. My system will not work with the ignition on. Could this be the override switch. Where would it be. Are there fuses? If so were would the be.
The switch seems to make contact when I press in, but not for out. Batteries are new, fully charged.
Any help would be a great help.
Thanks for all the help. Problem solved. Bad switch!!!
Thanks,
Chuck
  • With my Power Gear system I need to have the motor running to provide enough power to operated the system. Fully charged battery might not be enough to operate your system too. Can't see a lock-out system preventing the operation of the slides with the ignition on.
