AikenRacer's avatar
AikenRacer
Slide/camera issue
Just picked up the mh from the Cummins shop for a coolant repair. Of course, it was there for several days with no power supply. Got home and noticed when I shut it off, the rear camera stayed on. Also, we to let the slides out and they don't move. Almost like the mh still thinks it is in gear and running. Generator works fine. Cranked it several times and shut it off, wiggled the ignition key, checked the batteries and breaker. No reason for this issue found. Any ideas on what I might check??
  • Check the switch on the front of your camera screen. Mine can be turned on while my ignition is off. Yours may be the same.
  • AR, have you thought about turning off the chassis battery disconnect to see if it would reset the engine electronics?
    Just a thought.
    Mark
  • Both elec and hydralic. It almost seems like the mh thinks it is still running. That is why the rear camera stays on and won't shut off, the slides and the awnings don't work....????
  • Every time I pick up the MH from either Cummins or Freightliner, new problems arise so you are right!
  • If this goes the way I think it will, the shop will claim no knowledge of any of this - or it was that way when you brought it in.
