ichudov's avatar
ichudov
Slideout was stuck and bottom torn?
I have a Monaco Windsor motorhome.
A slideout seemed to be binding. I helped push it out, relatively gently and it did come out. I then went to look at is and saw that a piece of plastic underneath is torn and the wood has some damage.
Here's a picture:
http://igor.chudov.com/tmp/slideout.jpg
I am sure that I have to fix it, however I need to operate this slideout two more times. DO you think that it is possible?
Thanks
  • Before moving the slide in, cut the loose pieces off so they won`t bind, & raise the forward carpet flap up & see if the nylon type block is broke or if any screws are loose -- Lippert makes your slide & the block is a "Lift Block" -- Your slide needs to be adjusted, & always move your slides when your coach is in the travel position, NOT after you level the coach -- That will throw the slide opening out of square -- I know some will say that`s all wrong, but they don`t have a Monaco built coach -- The coach is mfg at the travel position, & not leveled -- If I can be of help, call me -- 480-540-7377 Bill Willard
  • Monaco don`t use rollers on these slides -- The use a nylon block that the slide goes over -- There is a fix that includes installing a "ski" made of thick aluminum that goes over the damaged floor -- It has to be thick enough so you can counter sink the screws that`s needed for the install -- I had the same problem as you & that is what I had to have done -- Contact Elite Repair in Harrisburg Oregon for the part & advice -- The # is 541-255-6231- or 541-517-1716 --- Bill Willard
  • It looks like a roller has stopped rolling.
    https://casshudson.com/22-rv-rollers-brackets
    JR
  • One of the bolt/screws that holds the roller may have backed out, happened on one of mine.
  • Interesting, I wonder whats inside the trailer that is causing the binding.
    Either way, your repairing something, I dont think you can ruin too much more by using the slide out. For good measre tho have someone help you push it in and out to save one wear and tear on the drive system.
    I think I would cut away the folded plastic etc to prevent further interference with what ever is hooking onto it within the slide out frame of the trailer.
