fcooper
Apr 01, 2014Explorer II
jesstrue wrote:
...text deleted
Now I'll just leave it alone and let the silicone spray dry and hopefully that will work. If not, or if it fails sometime in the distant future, then I will probably try the adhesive route. But how do I get the glass out of the track? ....text deleted
Unfortunately, you must remove the entire window frame from the RV. Then you will find a plate with bolts/nuts/etc either at the top or bottom of the frame than can be removed. After that, the frame can be split apart far enough to remove the window from the track.
It's really not that hard to do, and it should take about 20 minutes to get the window removed, the frame split and the window removed. Use new butyl putty tape on the window frame when re-installing.
Fred
38,769 PostsLatest Activity: Mar 29, 2026
