Does anyone share my problem.The slobber tube on my motor home is just at the edge of the rear mud flap. It was re routed there to avoid the goop from being sucked into the radiator. That did the tick...
I clamped a wide neck drink bottle with several holes at the top to let it breath to catch anything that drains out. I check it periodically to see if it needs drained. Inexpensive and stops it from slobbering on the ground.
