Does anyone share my problem.The slobber tube on my motor home is just at the edge of the rear mud flap. It was re routed there to avoid the goop from being sucked into the radiator. That did the tick...
As Brett pointed out, check for the correct oil level. I extended mine to the rear mud flap and only notice a little oil vapor on the flap and no mess on the toad. Good luck.
