GHOST1750's avatar
GHOST1750
Slobber tube
Does anyone share my problem.The slobber tube on my motor home is just at the edge of the rear mud flap. It was re routed there to avoid the goop from being sucked into the radiator. That did the tick but now it slobbers on the side of my tow. If you havehad that problem what did you do about it? :@
I think I asked this question brfore but let's see if anyone has aanother answer other than the ones I got. Just got a new tow and don't want to mess it up.:B
  • I clamped a wide neck drink bottle with several holes at the top to let it breath to catch anything that drains out. I check it periodically to see if it needs drained. Inexpensive and stops it from slobbering on the ground.
  • Hey darsben, I'm pretty familiar with slobber tubes but always looking to further my education. So please email some of those websites....
  • I did not know what a slobber tube was so I googled it. After the first 30 to 35 porn sites I fond this;
    http://www.irv2.com/forums/f101/slobber-tube-149503.html
    Hope it helps and thanks for the education
  • Run it into a small tank with a filter on the top and a 1/2" ball valve on the bottom to drain the oil.
