pnichols wrote:
Just for what it's worth, we traveled on highways above 11,000 feet in Colorado last fall. Our E450's V10 didn't even grunt up there moving our Class C right along keeping up with the diesel tow vehicles and little SUV puddle-jumpers around us.
However, our 24 footer probably isn't more than 12,500 lbs. fully loaded - including the DW's collected rocks.
X2 Been there done that... although our 2012 E-350 Nexus Class C has GVWR of just 11,500 which we usually are very close to and I often tow my Harley - bike and trailer are about 900#.
Still will never understand why no-one seems to actually read their owners manual. :h
How else can you explain the large number of folks who do not use Tow Haul and yes, unless you are running nearly empty/very light you should be using it all of the time. The many benefits of doing so apply going both up hill {and frankly especially} downhill. :S
The V-10, especially with the newer transmissions, is unbelievably bulletproof "If" you run it as designed by the engineers at Ford {can you spell Tow Haul?}. :B
