TechWriter
Sep 13, 2021Explorer
pnichols wrote:
What's difficult today is to find a small Class C that is built on a chassis that is specified for carrying way more weight in day-in day-out use than is required under normal circumstances. IAW, an overkill chassis under a smal motorhome is not easy to find new, should you desire one. ;)
OP here . . .
I'm not sure if you meant that newer small motorhomes don't have overkill chassis or . . .
Regardless, I said in my original post that my $35k budget doesn't allow for newer Class As or Cs.
So I'm forced to look at 2000ish models. While there are some 2000ish Class Cs that fit the bill, there seem to be many more 2000ish Class As. For example, if you're considering CCC (as I am), here are specs on two National RV Class A models . . .
38,782 PostsLatest Activity: Sep 10, 2026
