FIRE_UP
Apr 16, 2015Explorer
Sandy & Shirley wrote:
We just traded our 37’ Everest fifth wheel for a 37’ Georgetown class A. We did not trade our 2002 F-350 with the 7.3L because we still need a truck once in a while and the dealer would not give us a proper trade. We don’t need an F-350 dually for our normal small tow jobs and we want to be able to flat tow something behind our Class A, so we are looking for a small truck that can be flat towed.
Our max weight is 5,000 so we are looking for 4,500 curb weight. Our research shows that the newer AWD trucks can’t be flat towed without an extra pump to keep the transmission cool. As we understand it we will need a 4WD with a shift lever to switch from 2WD to 4WD with a Neutral position between the two drive modes, and we have to insure that the neutral position completely disengages the transmission from the wheels.
So, can anyone help us make a list of the proper trucks to look for?
Thanks in advance for any help
Sandy & Shirley,
Well, towing a small truck as you can read here, is done by many. And, many don't need a "Four Wheel Drive" truck (of any size) for their daily driver or, useful deeds etc. But, in the design of transmissions and gears and bearings and all that technical stuff, there are precautions that must be taken to insure that there is no damage, as a result of flat towing a vehicle, i.e. small truck, or any vehicle.
The smaller trucks, as in Ford Ranger, Chevrolet Colorado, GMC Canyon etc. are NORMALLY flat towable, IN THE FOUR WHEEL DRIVE versions. The Ford Ranger has some restrictions which, I'll get into in a minute. But, the Colorado and Canyon have no restrictions.
Toyota, as I know it, and, based on the Dinghy Towing Guides of all years, is NOT FLAT TOWABLE in any of it's trucks, 4WD or 2WD. That is of course unless things have changed very recently.
Fords "Ranger", in the Four Wheel Drive version, can be flat towed ONLY, if what's called an "NTK" kit has been installed and, modifications to the engine/transmission controlling units has been done by a Ford tech. And, NOT ALL YEARS of that Ranger will accept the NTK kit. Incedentally, an NTK kit is, Neutral Tow Kit. It's a very simple kit. It primarily consists of a fancy LED icon and bracket that is mounted at or, under the dash someplace in clear view of the driver. It has a light and an "N" on it.
Then, once that is installed in the truck, the truck is then "re-programmed" so that the electronically shifted transfer case, places the gears in that case, into a NEUTRAL position.
Now, a small word on "Transfer cases" They call them transfer cases because they "transfer" the power, from the transmission, to both front and rear drive axles. And, normally there are at least four positions in the selector.
1. 2WD = Two wheel drive
2. N = Neutral
3. 4WL = Four Wheel drive "low range" = lower gears for lots of power
4. 4WH = Four Wheel drive "High range" = all four wheels pulling but, in a higher gear range for things like sand running, snow running etc.
Now, there are manual shifting transfer cases which, have shifter sticking out of the floor, usually with a knob on the end showing those letters etc. listed above.
Or, there are ELECTRONICALLY shifted transfer cases. Those most often, have a knob or, set of buttons on the dash that indicate the icons and or numbers, listed above.
But, there are also electronically shifted ones that DO NOT SHOW THE "N" or, NEUTRAL POSITION. If, they don't show the neutral position, then GENERALLY they are not flat towable. But, there's always exceptions.
Anyway, enough blabbing for now. To make your life simple, the easiest way out for you is the Chevy Colorado or , the GMC Canyon, both in the 4WD versions.
And yes, when the TRANSFER CASE is shifted into NEUTRAL, it does disengage the drive train, i.e. front and rear drive axles, from turning the gears etc, in the transmission. And that's exactly what you want.
Scott
38,782 PostsLatest Activity: Sep 02, 2026
