Good Morning everyone. following up with an update. I spent Saturday morning installing the Air Force One on the coach. Actually I surprised how easy it was. First got the coack up on blocks, dumped the air bags, set the jacks and she was ready. I was able to install the air tank just in front of the brake assembly, this made for easy installation of air lines (nice and close) then it was all about cutting the supply and metered air lines. I was a bit nervous at first, obviously cutting the air lines but once cut I was able to connect all lines and then route the final air line through the existing wiring harness to the back of the coach. I was able to get a great location just rear of the trailer hitch pin on a solid surface.
Friday morning I had sent a photo to Demco to very the supply and metered air lines on my coach. Thanks Demco, fast reply and I was happy they were there if I needed them. Next week is the Truck side install and I believe this will be a bit more difficult!
