cccougar's avatar
cccougar
Snow on roof
Hi to all,
We live near Philly, and just recently received close to 12 inches of heavy, wet snow. It has been a brutal winter with snow fall totals. Should I be concerned with that much snow on the roof? We have a cover on it (not a blue tarp) and I'm thinking it will help with protection, but the shear weight is a concern. Should I get up there and shovel? Thanks.
  • Not to worry; the below picture is my 17 year old RV with 23" of snow on it that we got here in Central Oregon last weekend; then we got 4 days of rain... The key is having it covered, which avoids those expansion / contraction damages caused be the melting / re-freezing cycles. Shoveling off snow will most likely do more bad than good. Stay warm and dry.
  • Before I left the frigid north I swept the snow off the roof of the MH 'every' day. A lot of damage is done when the sun comes out and it melts the under layer and then at night THAT freezes. Can cause a lot damage to seams, vents etc as it gets under neath and heaves them. So I sweep it off every day instead of letting it get thicker and thicker with snow.
    The one thing I can tell you NOT to do is brush the snow off the cab over. I used the extended RV broom commonly found at RV stores. It has a big broad brush and soft bristles. So I thought it was ok to use on the RV..........well, come spring my cabover decals had feathered cracked edges.:(
    The decals are cold and brittle in freezing temps and me brushing the snow off feathered the edges.
  • I had 4 inches of ice on the roof of our Southwind, we just got 12 inches or more of snow today.
    I'm not concerned about the weight.
  • I've probably got close to that on mine and I hadn't really thought about it. I don't plan to do anything with mine.
  • Hi,
    I just remove the snow from the solar panels so the batteries can maintain a charge.
    Steve
  • If it has not caved in yet, do nothing. You run a bigger risk of damaging the roof by shoveling than waiting time out for it to melt.
