- 2oldmanExplorer IIThe 100% sure way is to use a voltmeter.
- Hank_MIExplorerThat's the way our Bounder worked and our Winnebago works that way as well.
- FormerBoaterExplorerAmerican Coach typically hard wires the solar panel so it will not be affected by
disconnecting your battery banks for storage.
Unless some previous owner changed the set-up, as long as the sun is shining you are getting a trickle charge. - pianotunaNomad IIIHi Mrrkva,
That depends on how the installer wired it. Get a meter. Measure the voltage at the battery bank when you KNOW charging is happening. Note it down. Then turn off the battery disconnect switch and check the battery voltage again. If it has dropped then you will have your answer.
Do you know how many watts the panel is? - Sam_SpadeExplorerOpinions you get might be helpful but you NEED a meter to be sure.
38,766 PostsLatest Activity: Jan 10, 2026
