JoeH
Feb 01, 2014Explorer III
rgatijnet1 wrote:
Go to most any large auto parts store and get a fine or medium CLAY bar. Using this clay bar with soapy water will remove any water spots as well as any bugs or other debris imbedded in your paint. Once everything is removed, you will have a glass smooth surface that is ready for wax. Much safer than any type of rubbing compound.
That's what I have had to do in the past... but I use a detailing spray with the clay bar instead of soap. To avoid the spots after you get rid of the current ones, either use a leaf blower to blow off the hard water before it dries, of get a deionizer and do the final rinse with water form it. Here's what I use now
38,705 PostsLatest Activity: Jan 14, 2025
