John_S2
Oct 06, 2013Explorer
Spare tire mount leaking on back wall by bed
After driving through some very heavy rains in KY recently we went to bed and I noticed that the head of the bed, which is on the backwall of our Class C was damp. I felt around and the metal plate on the inside wall of our unit was damp and causing the bedding to be wet.
I am in the process of removing the spare tire from the back and the plate that holds it to the Class C. Looks like 4 large bolts go through the wall to the metal plate by the bed.
It looks like clear silicone was used by the manufacturer (Coachman) and it did the job for the past 15 years. Should I just use clear silicone to seal it again. Figure I will caulk around the four bolts as they were caulked originally and also around the outside plate when I reattach it to the outer wall. Any suggestions from any of you more experienced RCv'ers out there? Any and all suggestions are appreciated. TIA
