jorbill2or wrote:
Tom/Barb wrote:
handy tool kit.
Had many tires change beside the road .. I don't have or want to carry the heavy impact driver and truck mounted compressor to run it or even cheater bars. And all the other "stuff" Let the commercial truck service truck handle it while I have a beverage or if in the outback drive the toad to town to get someone to do it. ??
To answer the op question .. yes they will call a commercial truck tire service truck to mount your tire beside the road.normally covers the expense If you knew who to call you could also make the call. They have heavy impact driver guns and the bars to remove the tire along with the 20,000 lb air jack to raise the coach to take it off to work on it. Great to watch done, not do. Especially on the side of the road not in a nice clean shop. Didn't deal with it 30 years driving truck and certainly won't now ...... no no no !
Carrying a tire can be less costly if you have a hard to get size. Provided you have space !
What you say is all well and good, but try to call that service truck when you are half way up the Casiar Highway or half way between Watson Lake and Whitehorse.
Worse part is knowing which tire you can change and which one you can't, Coaches like
my Newmar have rear axles that when you remove the wheel nuts both wheels will come off.
My coach must be jacked to remove a rear dual. but you can slip the outer dual off the rim with out removing the wheel.
Airing a big truck type tire is what most people can't do. I've seen some that even the tire shops couldn't do. when you can't get that tire to expand onto the rim, you are not going to get it aired on the side of the road.
The best tool you have is your cell phone.
I can change my 1000X 22s but I wouldn't unless I had no choice.
