kioticoachman
Aug 23, 2015Explorer
j-d wrote:kioticoachman wrote:
2000 Ford Coachman E-350 w/ Triton 5.4L V8 2V engine
Is this the Model Year of the Coachmen Class C, or the Ford E-350?
It's common, even usual, for Chassis to be a Model Year earlier than the Coach Model Year. If E-350 turns out to be 1999, have Ford dealership or Ford specialist shop install Ford plugs. The Ford "modular" engines, V6, V8 4.6, V8 5.4, and V10 had sparkplug issues different from 2000 and later.
Good call on naming it as "2V" since you seem to understand that NO E-Series got the "3V" that came out mid-2000's. Those, too, have plug problems, but they're from different issues than the early 2V's.
The title lists it as a 2001 Ford Coachman. If I got this right, As far as I can determine it started out as a 2000 Ford E-350 Heavy Duty Chassis that Coachman used to install their 2001 model 195 - rk RV on. If that make sense? It is a Model 195-rk - 2001 - Class C Coachman. Hope that helps and thank you for your input. KC
