usersmanual
Oct 26, 2016Explorer
http://www.westlandsales.com/ariston/service_manuals/washers/AW129(49)_SvcMan.pdf
how are you able to run the machine to fill with water to have tested the pump as you have so stated?
F 11 one thing I see it says Check pressure switch (just a idea)
it monitors empty- full and "Overflow"
want-a-be wrote:
I forgot to open the gray tank valve, the tank filled up and the washing machine pump water everywhere!
After clean up the washer goes thru a couple of cycles and then we get a code F11.
Code F11 says, not hot fill. ( hot water ok). Ambient temp. Is likely below freezing (it's 70 degrees here) Make sure water valves are on (they are on ) Check kinks in hose (no kinks). Tried different wash cycles and temps. Also put drain hose in a bucket and the pump works, check filter clean out, It's ok and the pump impeller is clean and turns!
All comment greatly appreciated!
38,782 PostsLatest Activity: Aug 11, 2021
