want-a-be
Oct 26, 2016Explorer
To test the pump we poured water in the washer and put the drain hose in a bucket, the pump works fine. Don't know where the pressure switch is located. Was hoping to come up with a fix before I have to remove the unit. Also as I have said the washer will go thru some of the cycles before we get the F11 code.
38,782 PostsLatest Activity: Sep 10, 2026
