want-a-be's avatar
want-a-be
Splendide Ariston Washing Machine Model ARWXF129W
I forgot to open the gray tank valve, the tank filled up and the washing machine pump water everywhere!
After clean up the washer goes thru a couple of cycles and then we get a code F11.
Code F11 says, not hot fill. ( hot water ok). Ambient temp. Is likely below freezing (it's 70 degrees here) Make sure water valves are on (they are on ) Check kinks in hose (no kinks). Tried different wash cycles and temps. Also put drain hose in a bucket and the pump works, check filter clean out, It's ok and the pump impeller is clean and turns!
All comment greatly appreciated!
    so if I'm reading this correctly, it does run for a few cycles before you get the F11 or DID it run for a few cycles and now it won't run at all?
    On our Splendide Model 2100XC, it will give an error of F13 if the lint build up gets dislodged and blocks the inside part that connects to the dryer vent.
  • Sounds like the computer has become confused. Have you un-plugged it and "rebooted"?
