Kidoo's avatar
Kidoo
Steer Axle Hub inner seal needed Monaco Roadmaster
Hi, I have a 2003 Monaco Roadmaster R4R, Cayman 34, DP, and my front hub is leaking. I need a Part Number, any help appreciated.
Thanks
  • DSDP Don wrote:
    "Kidoo".....Your Cayman has drum brakes. Where are you seeing a caliper and disc?
    Call this company.....they specialize in Monacos. They may have the seals, or at least the part.
    Source
    Well, I just had the rear caliper and disc replaced, I took it myself to the garage. I will do the front, yes I have disc brakes!
  • msmith1199 wrote:
    If it helps, just today I was scanning all my old receipts into digital format and I found the one where I repaired this exact same problem in 2013. I had it done at the Freightliner dealer (most expensive place) and they replaced the brake pads. Total charge was $294.90. I'd gladly pay $300 again over trying this job myself.
    Do you have part number for the seal?
    No, but I don't have the same motorhome as you either.
