wa8yxm wrote:
D.E.Bishop wrote:
Just a quick question, what is this box you talk about?
Many RV's have a simple wall plate. it has a 12 volt outlet, a Switch, A light and an antenna connection.. The SENSAR pro will replace it.
I have a "Box of many buttons" (BOMB) properly called a Matrix switch
Now think of this matrix
Television# Ant Cable DVR DVD SAT AUX
DVR
AUX
YOu have a push button in each BOX of the matrix allowing you to select any source to any destination save you can't send DVR to DVR.
My Sensor Pro is in the line from the BOMB to the Roof.
I am fully aware of all of this, what I was asking the OP, is what box has he got hooked up. To be back to a basic TV set and antenna, I suggested he eliminate the BOMB and all other peripherals.
It seems like with many used RVs, the original owners have modified some stuff. I was just suggesting that he by pass everything but the Sensar Pro and the TV set. If he is still having problems pulling in all the stations he had before, there would only be the newly purchased Sensar Pro, the direct coax or the television set at fault.
He did state he bought the Sensar pro and new head. I am going to step aside, there are too many experts helping and clouding the issues.
