festag's avatar
festag
Stranded in Suffolk
We just took delivery of our new motorhome about two weeks ago. Yesterday afternoon we pulled into a gas station to get gas and have lunch. We put the galley slide out and can not get it to come back in. Initially it would come on about 6 inches and stop. After someone at the dealer tried to talk me through some steps, it doesn’t respond at all (no motor activity). Keypad flashes alternately between the red fault code light and the green room or lock movement light. Slide is a power gear on a 2019 Southwind 36P. I tried manually cranking in the slide, but could not access second motor. Maybe there is a different way to get to it, but the closes I could get was removing a steel plate from underneath coach. Could see motor but could not reach with ratchet. Anyone in the Suffolk, VA area know of a good mobile repair place to help get the slide back in. Stayed here last night and looks like we will be here again tonight being a Sunday. Hope there is some help out there, thanks in advance.
  • Couple of quick questions. Was the MH engine running when you tried to activate the slide? Was the parking brake on?
  • I would also look at your owner's manual, or talk to the dealer, to find out what you need to do to MANUALLY retract your slides. Most have a procedure to use if the system has failed.
    If you do have to use the manual method, I suggest that you use your levelers to "tilt" the RV so that you are moving the slide downhill rather than uphill. No need to fight gravity.
  • JaxDad's avatar
    JaxDad
    Explorer III
    I hope you know, and if you don’t, the dealer told you, the coach must be level for the slides to work properly.
    If the coach isn’t level the slides may go out but not come back in, or vice versa.
    Try relevelling the coach with the slide control turned off, then turn it back on and see what happens.
