skpiste's avatar
skpiste
Sub 20' Class C - Ford 5.4L 5 Spd or 6.8L 6 Spd
So I am in the process of buying an Adventurer 19RD former rental up in Canada. Wanted something that can handle the cold and this is the closest thing to a Triple E. The only thing it lacks is the brilliant engine heat ported to the holding tanks (although the furnace heats them).
They have 3 years available: 2016, 2017 and 2018. The latter comes with the 6.8 mated to the 6 speed Torqueshift. The 16/17 have the 5.4 w/5 Speed TS. 350 chassis with single rear wheels.
UVW is just shy of 8000 #'s (with fuel if I recall) and GVWR is 10,500. Doubt I will ever load it that heavy but you know how that goes.
QuadVan will be converting it to 4x4 with taller tires etc. 95% of driving will be on flat land with 5% heading to mountainous resorts. Will NEVER tow anything in the Winter and not very likely in the Summer.
So should I spend the extra 8 grand on the 2018 or will a 5.4 be adequate ?
Fuelly is showing the 5.4 to have a significant advantage for MPG:
***Link Removed***
***Link Removed***
I do take these numbers with a pillar of salt but there are quite a few Class C's included.
I have spent a week reading up on the subject and the waters are even muddier. If only I could get the 3.5 EcoBoost we would be done here !
TIA,
Paul
  • Since you are doing 4x4, I'd go with the V10. It'll have more torque and better gearing for if you leave pavement, or end up towing heavier in the future. And will me much easier to sell if you ever decide to change things up.
    The 5.4L advantage gets narrower as profile goes up, since most of the load is from pushing wind. I think the reason you see a huge delta on fuelly is simply that the 5.4L was biased towards van bodies and the V10 is biased towards RVs and box trucks. In fact, with the 6-speed behind the V10, it might get the same fuel economy as the 5.4L with the 5-speed.
    You'll probably 11 with the V10, and maybe 12 with the 5.4L
    Another advantage of the V10 is the nearly silent idle, in case you need supplementary power or heat.
