JeffRil's avatar
JeffRil
Suburban Furnace Problems
So my dad gave me his old rv that he just replaced the main board in the furnace its a Suburban model NT34 S and it seems to run fine about 3 time, then it goes to ignite the 4th time and will not ignite, fan runs, and there is spark but no fire, I have taken it apart and cleaned it all and re-thread taped all the gas lines, it is getting propane because it runs the other 3 times just fine but then wont start unless I turn the thermostat completely off and then back on again.
If anyone has any ideas or any way to point me I would really appreciate it, Thank you in advance.
  • and you have to have a good 12volt source. meny a times all thats wrong is the battery is low,even when plugged into shore power.
  • Check the feather switch. It controls the gas valve and must be proved before you get gas.
