captron33ExplorerJul 02, 2018Suburban water heater2006 was travel supreme with dual gas/ electric 10 gallon water heater.....will not heat on gas or electric. Sounds like a common part, anyone know what its called. Thanks.
RgtopdaExplorerJul 02, 2018Does the flame try to light. can you hear the spark popping? Is the ground fault plug popped..Need some more info!!!
Related ContentSuburban SW12DEL Water Heater On/OFF switch melts???Atwood water heater problemWater Heater Replacement RecommendationsReplacement of Suburban water heater...Water Heater Leak on start up.
