bobndot
Aug 18, 2020Explorer III
Open the outside panel that allows you to view the rear of the fridge. Make sure its plugged in. There should be an outlet dedicated to the fridge.
Some people unplug them because some older and state park campgrounds that insist on using GFI outlets for 20 amp service will constantly trip when some rv's plug into them. Those people will unplug the fridge and run it on gas 24/7.
Do you have a bathroom fan in the roof vent ?
how do you turn it on/off ? There is a small switch on the fan itself but some rv's also use a wall switch. Same goes for the bathroom light, some have two switches.
It could also be a dump valve light switch if you have an outside light near the dump valve.
