stan909
Apr 25, 2015Explorer
Not to mention that if you take a vehicle to a place that may be doing repairs, isn't it possible that they may find repairs that may not be necessary? I will use the OPs example of sticky toilet valve. I bought my van last August and it had the same problem. I was a little nervous but found that simply putting a little water in the bowl and letting it sit a little enabled it to work. Incidentally , the blade valves at the dump pipe may have a similar problem.
