The table in the MH is looking bad. The flimsy plastic that was applied at the factory is peeling off around the edges. Anyone had this problem? How did you re-cover the table? Thanks!
Lorraine: not sure. It is a very thin plastic like material that probably was put on with contact cement and heat? It fits tight with no wrinkles on the curves. It is just the edges going bad...for now. The table has curves on the aisle side and the edges are curved to the table top.
