The table in the MH is looking bad. The flimsy plastic that was applied at the factory is peeling off around the edges. Anyone had this problem? How did you re-cover the table? Thanks!
You can use contact cement to repair it. Although as I understand it manufacturers have to use water based cement but individuals don't. I use solvent based and it seems to hold much much better. I haven't tried to buy quart cans so don't know if larger amounts are available but tubes are.
