The table in the MH is looking bad. The flimsy plastic that was applied at the factory is peeling off around the edges. Anyone had this problem? How did you re-cover the table? Thanks!
If you want to get fancy, you could take it to a cabinet or counter top shop. They could stick about anything you want on and it would stick.
As Clay said contact cement will stick just about anything you want but leave some extra over the edges to be trimmed later. Once contact cement touches there's no moving it for position. The shop will use a trim router and then band the edges.
