The table in the MH is looking bad. The flimsy plastic that was applied at the factory is peeling off around the edges. Anyone had this problem? How did you re-cover the table? Thanks!
I can't believe they would manufacture something so cheaply. You could have take that to a cabinet shop and have it laminated, although that covering would have to come off, maybe with a heat gun and the edges would need to be squared off. I believe it cost me less than 100 dollars to do it myself if you want to tackle it yourself, but you will need a router at least to do the job.
