clayhubler
Jun 14, 2018Explorer
Here is so me info I should have included in the post from the beginning, but at the time I didnt think it was related.
The tach quit before I replaced the alternator on a trip last year. When I replaced the alternator, there is a wire that was hooked to the old one, but is not hooked up now. The guy that I got the alternator from was from a diesel electric repair shop, and he really seemed like he knew what he was doing. I had already tried several autoparts stores, and they hadn't come up with anything. This guy saw the alternator and recognized it immediately.
I asked about the wire, and he told me that it wasn't needed because the new alternator didn't need to be energized like the old one had, and thats what the wire was for. However, he said it could be hooked up with no harm anyways, so that's what I did. Keep in mind at this time the tach was already not working, so I didn't believe the two problems were related. After the swap, I continued my drive home with now issues, the wire still hooked up. When we got home the next day, I could hear a tick, tick, tick at the back of the coach. After some investigation, I realized it was the hour meter still counting off, even when the engine was off. Knowing that the alternator swap was the only thing that had changed since the correct operation of the hourmeter, I disconnected the aforementioned wire and the meter stopped ticking off.
The wire remains disconnected. I do not know if the hourmeter runs when engine is running or not, but I am not as concerned with that at the moment.
Sounds like Mountainair05 may be right, but I don't know if I have a leece neville or not.
I am pretty sure now that the tach and the alternator are involved with each other, an allison transmission specialist told me as much when I questioned him about the sensor that I suspected was the crankshaft position sensor, but was in fact the engine speed sensor. He said the tranny has nothing to do with the tach, so I am back to the alternator, but even if I hook up the wire again, the tach doesn't work. This alternator looked identical to the old one, with terminals in the same locations and everything.
38,782 PostsLatest Activity: Sep 10, 2026
Related Content
- Feb 01, 2026Community Alumni
