barlow46
Sep 30, 2014Explorer
Adjusting it by the gauge in the engine compartment will work for an estimate but you really need to go to the scales and do your adjusting there based on your weights. Remember added pressure on the tag increases the weight on the front axle so check that weight each time you cross the scales. After you get it adjusted where you want, then take a look at the gauge and use it for a reference based on your load.
38,707 PostsLatest Activity: Feb 18, 2025
