Executive45's avatar
Executive45
Explorer III
Oct 14, 2015
Tag Axle Question
We traveled US95 yesterday through Nevada. (Between Carson City and Las Vegas) If you've been on that road you'll know there's nothing but desert and abandoned towns, or at least one's that should be. Anyway while cruising along I got to thinking about the tires. With that in mind I wondered if I had a flat out there on the tag, could I simply remove that tire and drive on into Vegas? Or if one of the other tires went, could I use one of the tags as a spare? What, if anything would be the result? I understand the tag is there for weight distribution. Reasoning says it would be possible unless you're close to maximum weight. I also thing both tag tires would have to be removed but maybe not. Any "experts" out here that can give me a definitive answer? Thanks....Dennis
  • Ivylog's avatar
    Ivylog
    Explorer III
    If needing a tire in the middle of BFE (without cell service) I would remove the unmounted spare from my roof and install it... yes I'm still capable of doing that. If no spare then I'd remove one of the tag axle tires and put it where needed and increase the drive axle tires on that side to max pressure. I would take the air line off the airbag on that side and plug it off so it does not push the axle down too far.. Note to self... get a plug that will fit that hose from my shop although you could bend it 180 to seal it off.
    On the Monaco's that lift the tag we have a pair of air chambers and chains that raise the tag axle. If the side without a tire still needs to be held up then changing the length of the chain would be the easiest way to hold it up BUT the air line would need to be plugged on that side.
    If you remove both tag tires there is no need to chain it up as the shocks will stop it before it hits the ground BUT you need to make sure the arch that goes over/under the drive shaft is not going to hit it. If it is going to hit, it would be easy to reroute the tag's airbag lines to the air chambers that raise the tag IF you had a pair of male couplings... add two couplings to the list.
  • Dennis.....I would think that it would depend on the coach. Some, like mine, only take the pressure off, but still leave the axle down. Some lift all the way off the ground.
    You bring up a good question and maybe it would be smart to have a way to support (chain) your tag if you needed to remove the tires. I think even if you had a liftable tag, removing only one rim would probably make the opposite side want to press down and angle the axle in such a manner as to cause issues.
    I think in my case, in an emergency, I would run the tag tires up on blocks, release the air and chain the tag up. Mine would also need the air disconnected as mine goes back into service at 5 mph.
    I wouldn't have any concern about the weight on the duals, since it would be an emergency issue. It might be a good project to design a chain with hooks or some sort of connector that would fit, if you needed to chain the tag up.
