hypoxia wrote:
One of mine was intermittent, changed the control box which fixed it. Had to pull the toilet off the floor but didn't have to disconnect the hose. I have not heard of the switch panel going bad although possible.
Do you have the two button panel with the tank level light?
Techma parts My bad control was like the 38646 part.
Yep, that's the touch pad, I have.
However my toilet is the Tecma Easy Fit, not the Silence Plus.
So you're saying that the control box is not the flush pad and is located under the toilet?
Thanks for the link, as I may need it.
