Canadian_Rainbi's avatar
Feb 24, 2016
The continuing Norcold 1201LRIM Saga
Well it just keeps on going. As I mentioned on another thread:
We are in the process of studying our options;
-New heating unit;
-New heating unit, new control board;
New heating unit, new control board, new doors(door seals aren't replaceable);
-New Norcold 1201LRIM or equivalent;
-New residential fridge, added batteries, inverter, solar panels and controller to what we have now.
The options changed slightly when I we opening the left hand door this morning it came out in my hand. The lower hinge mechanism which screws into the plastic door edge (What idiot made that decision?)tore completely out.
Of course we are in Mexico. I'll have to see if I can find a hardware store and find something to use. I may have to whittle a wood spacer to avoid crushing what remains of the plastic door edge. I think I'll have to drill and bolt right through plywood panel on the bottom edge of the door. For now it is shut and seems tight--no door open alarm going off. God know what will happen when we hit the first bump.
Photos later.
  • When you speak of the control board, have you taken it to an electronics repair shop in Mexico? They can take it down to the lowest level and replace just about anything.
    We recently had a board go out on an old television. Fixed for 180 pesos. The board was no longer available. These guys know how to test and repair. A board is a board no matter if it´s from a television, stereo or an rv. Worth a try and nothing to lose.
  • Passin Thru wrote:
    Duct Tape The Handymans Best Friend! Red Green
    I'm a Gorilla Tape convert.
  • Bungee cords are your friends!
    I know which choice I'd make. It would be residential with 600 watts of solar. (300 watts for the fridge and the rest for battery charging and other loads).
    Velcro may help to get you home, too!
