toedtoes
Sep 02, 2018Explorer III
winnietrey wrote:
Pasusan and Gemsworld
I respectively disagree, I can run a tape measure as well as the next guy.
Here is the deal, slide no slide the interior diameter is the same. (about 97 inches more or less. Slide gives you another 2 ft out for 6 ft
Yes the space is extended, but the point is that an RV designed without a slide optimizes the available space. An RV designed with a slide optimizes the space with the slide out - so when you are suddenly unable to access that extra space it has a greater affect than if you never had a slide.
