BillHoughton's avatar
BillHoughton
Explorer II
Jan 11, 2019
The sins of the previous owners...
...are visited upon the subsequent owners.
The awning on our Itasca is fastened to brackets that stand it off from the side about an inch at the narrowest, an inch and a half at the widest, and about five inches high. One of the two previous owners - I suspect the original owner - decided to glue some weatherstripping, of the type used to seal car doors, at the bottom of this gap. I'm not sure what the goal was. To keep water from dripping down behind the awning (that you're not supposed to leave open when it rains anyway)? To reduce wind noise?
Whatever the intent, the effect was to trap leaves and other detritus on the gap, which buildup then trapped water. Fortunately, the awning's backplate is aluminum, and the RV in that area is fiberglass and aluminum; so there's no rust-through (there is some rust on the brackets to which the awning gets fastened; I'll need to address that before putting the awning back on).
Removing the weatherstripping took several hours, about an hour of which was dedicated to figuring how to to strip the adhesive off (Goof-off and a sharp, stiff putty knife was the final answer). At least I won't have to do that again.
  • The guy that owned my rig before me (may he rest in peace) must have been related to MacGyver. When replacing my shocks I wondered how the guy managed to get the bolt and nut tightened because you can't even get your hand up in there never mind a socket or wrench.
    This is what fell out:
    He had wrapped some wire around the nut so he could hold it just tight enough for the lock washer to grab. Clever.
    Ever since then I find all sorts of interesting repairs. The best is a $0.50 fly swatter whose handle had been repaired with a stick and electrical tape. I kept it as a reminder of what I'm in for when I come across some of his repairs.
